Idec Micro-1 Data cable pinout required
jBetts said:
Does anyone know if this will work?
I highly doubt it. Although, there's a good chance you could destroy the COM port on the Micro and/or your PC... :nodi:
You need a converter, period.
beerchug
-Eric
Hi jBetts !
I have the sch of Micro1 plc prog. cable, I need the windldr software.
Can we exchange it?
Best regards.
good day!
Ive been working with microsmart plc and its working good. now, winldr software have the option for micro-1 plc but I dont have the cable, is there a way I can do to have my micro plc working as well? or do you have an idea of an adaptor or something i could match with the existing cable I am working with in order to access micro-1?
That PDF is right on the mark, I have a cable that uses that
Hello everyone,
I first came across this forum after I bought some idec Micro-1 PLC's. I have yet to do anything with them. The reason I'm posting is that I have a copy of WindLDR v1.0 and I also have a cable with the converter circuit shown in the schematic pdf above, I can post some pictures and even a board trace if I get time. Would this be of any help?
Hello, I am a new member. I use an old automatic wood oven. Its controlled with a IDEC Micro-1 PLC. There is now a mistake. When I switch on the...
1,105
Joe here from Palm Gaming- hoping to find some help here- we run a custom made heat press- we make ***** chips for casinos- the press has the orig...
7,333
I have a machine that is new to our plant that has a Idec Micro 3 FC2A-C24A1 processor. Does anyone know if WindLDR ver 4.2 will talk to this...
3,677
I am working on a project and was curiouse if anyone knew or knew where i could find the schematics for the Micro-1 and Micro-1 expansion plc's...
1,978
Hello there! Need help for micro-1 idec plc interface pinout. Units were obsolete and it seems quite hard to find means to access such PLC...
3,434
