Operaghost
I know im continuing to add detailed information i should have started with..
I can get remote access for programming through the HMI. It has it built in.
This is why I wasn't going to use an E*w*n this time around. By using the HMI independently in each system as access if IPs are the same i will not know which system im in, unless I throw a comment in one of the programs maybe, then i can check.
I also am using L3x controller, which has dual IP, which i planned on leaving A2 open so they could use it for their plant whenever they decide to.
So I would still recommend changing IP addresses using whatever scheme makes the most sense. That way when the day does come that they all need to talk to each other, they will be ready.
I like the idea of keeping the last octet consistent for each device. So for each system the PLC is always at x.x.x.10 while maybe the HMI is at x.x.x.50. But it can be trickier since those would be considered separate subnets. Connecting them from your PC might be a little more involved.
Your original idea of using 10, 20, 30, etc.. for one system and 11, 21, 22, etc.. for the next system works too. And everything is on one subnet so connecting to it is very easy.
OG
