mubinulhaq
- Join Date
- Apr 2002
- Posts
- 6
I want to ask "is plcs programming is usefull for a person working in industry as technologyt and he get job easily if he has plc programming skill". please!
Knowledge of the languages of PLC programing is one thing, but the experience of what you will be programming is another thing... This only comes with a lot of time in the field with many areas of automation... You may get a job easier than someone who has no knowledge of PLCs, however to keep that job requires much more experience...and he get job easily...
In Ozz that is a BIG yes. A lot of the larger older power stations are not PLC controlled but generally the new ones are.If you are interested in power distribution and generation, the answer is "a little".
In that statement is a keyword..Knowledge.Knowledge of the languages of PLC programing is one thing, but the experience of what you will be programming is another thing...
Simple answer is NO, it requires more.I want to ask "is plcs programming is usefull for a person working in industry as technologyt and he get job easily if he has plc programming skill". please!
rsdoran said:Its a job that usually derives from having mulitple skills/training.
BobB said:In Ozz that is a BIG yes. A lot of the larger older power stations are not PLC controlled but generally the new ones are.
In our state (NSW) the distribution control and monitoring system ia also PLC based. The brand generally used by these people is Toshiba.
About a year ago I had to go to a power station with a fault - and that was controlled by a Toshiba PLC. It was an obsolete model and I offered to upgrade it to a different and current brand. No, they said - we use Toshiba throughout.
