irondesk40
anyone ever designed a impulse heat sealer. Looking at putting together a sealer bar using Nichrome 60 wire and automatically controlling it to cycle in the program on a protype machine i have built using a micrologix 1400 and Red Lion HMI unit.
Automatically cycling etc. is pretty straight forward but not had any experience with Nicrhome type heating wire etc.
the sealer bar will be 6 feet in lenght and need to operate at 600 degrees F.
I looked it up and the Nichrome 60 wire requires approx. 5.1 amps of current when stretched straight to reach 600 degrees.
I was looking at using a output of the plc to turn on relay to supply power to the primary side of a transformer.
If the output of the transformer is 24vac and i would need 5.1 amps then since P=V*I then it would require 122 watts.
If I take the 122 watts and divide it by a power factor of .6 then i would need a 200va transformer.
If i needed to pulse the heat to the heat bar I could just cycle the relay turning on the transformer on and off with a timer in the plc.
Am I way off base here? If so, could someone tell me what I may be overlooking?
