Incremental Encoder Counts to Position
Cody Anderson
Nov 2020
Brockway
36
Hello,
I am trying to take the counts I am getting on my plc from an incremental encoder and use them to keep track of position. I have never done this before and I am having trouble finding examples of what all I need to do. Can anyone help? Thank you!
That's doable it is done often
The first thing to do is set a known home position and and on powerup drive it home
then it's a simple matter to keep track of the counts up-down from thee.
i would recommend using a high speed counter to make sure you get all the counts
I have done it many times over the years
Way back when the PLC2's were new PLc5's
Micro Logix, Compact Logix
Please keep in mind their are a lot of things to consider when doing it.
One thin I have learned steel wheels on steel rails can give yo a lot of problems
a better way is to consider using a laser measuring system
i find they eliminate a lot of the problems with encoders and counters
projects include traveling scales for a truck loading system
hook position on a crane
Hello fellow members :) We are trying to refresh an old production line in paper bag packaging industry. We are using Sick NT6 contrast sensor...
1,560
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
291
Hi all, I am using a B&R X20 unit and want to integrate an incremental encoder (OUT A, B, & Z). I have three BOOL digital input pins for my A,B...
452
A bit of background here: We use an incremental encoder with a counting module in our PLC configuration. Using dual phase / quadrature counting...
26
8,960
Good Afternoon , We are thinking of using a BEI Incremental Encoder for one conveyor control , but keeping track of the speed of this...
1,719
