Infrascan 5000 to TSX Micro
chud
Oct 2007
KALAHARI
1,123
Ive got a log sorting system using a infrascan 5000 scanner. I'm not to familiar with this scanner as we normallyuse a different type. This scanner uses Rs422 which i convert to rs232 and then read on a Tsx micro 3721. I'm using a scp111 rs232 pcmcia card on the micro.
When I connect to the scanner using the scanners own software (scan view) the comms are fine and the right information is sent. I even get the right info by using Rs232 analyzer from my laptop. The problem comes in when sending commands or requests from the plc. I do this via the debug screen on channel 1. If i want to send a request of 82 hex, i type 16#82 in and keep on getting the same response from the scanner.(And no it is not a response from the pcmcia card on the plc). Is there maybe an end of line character that needs to be attached to the command, or something small that i'm missing?
I doubt my comm settings are wrong as they are the same as the other 2 softwares that comm to the scanners
Any help or suggestion would be much app.
Problem solved. Damn documentation of the infrascan was wrong. Needed Ascii instead of hex
Anyone ever used these scanners before. Having real issue getting any communications going to it. Scanners use Rs422 protocol which is converted...
1,477
I am connecting to a remote device. When attempting to upload I receive an error that states: Error: Auto_Functions: The Import was aborted due...
102
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
83
Hello all, I am currently facing a problem with a Pro-Face HMI PS5000 project file download. I have tried using GP-ProEX SP1 (4.09.350) and...
45
