Input needed on Protek S2405 Scope meter
OFG
Nov 2005
Ohio
19
This is a little Off Topic, if that is a problem please delete this message.
I have need of a scope meter about once a year or so – usually for checking for noise on power lines for electronic controllers.
My employer cannot cost justify one (and I don't blame them), the nice Flukes are $1500.00 and up, used on ebay.
I found a Protek S2405, 5 Mhz and with the specs I need. Actually I don't NEED one at all, but I am getting more interested as I think about it.
I can get it for $350.00 new, but I would feel better if I talked to someone that had experience with one.
This unit is probably lower quality than most of the experts here would normally deal with, but hey, it's my dime! ;- )
Does anyone have any direct experience with this model? Is it acceptable for a low-end scope meter?
Thanks in advance – OldFatGuy.
the 5 mhz may be a little low of a sampling rate compared to the average Fluke I doubt it will provide much indication on fast transmition signals but for noise etc it may provide some indications.
Ok so here's the poll... We need a standalone device that can send an email or SMS message on an external contact closure. It will connect to...
2,707
Hello All, I have a Parker CTC touch screen Which connects with M340 Modicon plcs and also comunicates with a data aquisition computer using...
1,560
I'm a PLC newbie. I have an eddy current device that measures the "runout" of a shaft. It has an output of 0 to -24Vdc. I will set it at a...
5,824
Hello all, I'm a Plant Electrician with very limited knowledge when I comes to PLCs. Our programmer had a bad accident and is unable to help...
2,892
Hi, I have DL305 series PLC using DL340 CPU & analogue input card F3-04ADS, which have been running for few years without any major problem...
3,982
