input triggers a data file to be sent via RS232 help
benrapley
Oct 2011
berkshire
hello
i have a sign that has a RS232 input and i want it to automatically change via and input state change i have captured the file via hypterminal but not to sure what plc i need and what code to write
any help is good help
ben
ben, try going to automationdirect.com they have several models that do a simple "v print" the trick is the coms setup but its asci........ more details I sure would give you more answers.
Best regards, Steve
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
45
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
87
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
263
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
87
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
91
