inquiry about wincc web navigator
Lil Saleh
Dec 2016
Damascus
I want to use wincc web navigator.
How can I connect the scada station to internet if I use ethernet network card to connect the station to the automation system?
1) add a second network interface
and/or
2) use typical network security measures to allow only limited access (VPN/firewall/NAT)
I know that Web Navigator can be run off of a client that is a dedicated Web Server. Especially if you want more than a couple web clients, this is usually recommended, and helps increase the security.
Hi everyone, got a Siemens S7-1200 collecting data off one our furnace lines. I'm getting some interesting activity I'm working on cleaning up in...
708
Hello all, This is just a general inquiry, I am a new control systems engineer and would like your insight on control systems upgrade. What...
2,747
We are replacing a piece of machinery with a newer version. The new assembly has 5 TCs which are closer by far to the operator station than the...
2,263
In Allen-Bradley world (Controllogix Rev 30 controller) is PID scaling ALWAYS set to match the input card / sensor scaling? I am simulating a...
2,376
Hi, I have an old unit HMI with model PA10T-133 (PA Powerstations series). 1. I just have an inquiry whether which particular software to use...
1,838
