install SQL Server 2019 on Window 10
mike3475
Feb 2013
brooklyn ,NY
334
Hi, All:
I have a project to replace 3 old window 7 PCs with new window 10 PCs.
the 3 old PCs: one is FTV SE server, other 2 are SE clients (identical), the application is network distributed, version is 8.00. i installed all FTV SE software (V13.00) to 3 new PCs and window 10, since we use FactoryTalk Alarms and Events (alarm server), we need to install SQL server 2019 in FTV SE server only, not sure need to install it in FTV SE clients or not.
my coworker give to me SQL server 2019 file, but i got confuse with file, the basically need to install two files:
one file is SQL Server Management Studio, i know it is the last file, no issue.
another is SQL Server 2019 Express, i don't know which file is for it.
please guide me with this issue.
Thanks!
SQL2019-SSEI-Expr is SQL Server 2019 Express (downloads necessary files from the Internet for installation)
SSMS-Setup-ENU is SQL Server Management Studio
SQLEXPR_x64_ENU is SQL Express... but I don't see a version. This is an offline installer. If you start it, you can see the version. If it's 2019, you should continue to install.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
123
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
89
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
102
Hi Deal All I had a issue With Rockwell Software try to download HMI but always give error (Unable to the Load Application) then rest the PC but...
113
