FT Client Freezing after FT Linx reinstall
celso3093
May 2021
Brazil
17
Hello,
We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After a power failure, it wouldn't work. The solution we found was to uninstall all FactoryTalk softwares and then install it back again. At first, it seemed to be working just right, but soon we realized that FactoryTalk Client was kind of freezing sometimes. The buttons on the screens wouldn't perform any action when we click it. Looking at the Diagnostics Viewer every freezing time I get messages like:
  • Driver Ethernet re-established a session to "IP" (XXX.XXX.XXX.XXX)
  • Drive Ethernet lost communications to "IP": connection reset by peer
The devices that own the IP's that are shown on those messages are not important to the operation (we use only PLC's in the Communication Setup). I get those messages only on one of the stations.
The FactoryTalk Linx drivers and devices listed on both stations are pretty much the same. I can't understand why it happens only in one station.
I tried deleting the problematic devices, but it seems to me that the Ethernet driver autobrowses the network and I can't find where to change that behavior.
I'd appreciate it if you guys could help me with this situation.
Thank you!
I tried to delete all shortcuts and create them again. Didn't work.
Then I tried to delete the RSLinx Enterprise server. No luck too.
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
71
Hi everyone, I've got some trouble lately with a client and his communication with the server. I'm a beginner, and the project was not orginally...
88
Hello, I'm working on a laptop that needs FactoryTalk Activation Manager installed on it as a host along with a Hyper-V VM client on the same...
99
AssetCentre Client loads correctly on the server, but when going through another machine the client never presents a splash screen; however, it...
151
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
102
