Installing WinCC Demo Version
plc-friend
May 2005
26
Hi, I got a demo CD for WinCC V6.0 but when I was going to install it I realized that I´m missing Microsoft Message Queuing.
Does anybody know if I can download a trial version of this program? (I´m usin Windows XP Home)
Thank You
As far as I know Siemens only guarantees that their current software versions (and WinCC 6 is a current version) will work on professional Windows, beit XP or 2000. I also think (from experience) that the demo versions are actually the real thing without an activation. So, it might be hard to make XP Professional out of your XP Home, I think you'll need a lot more than Microsoft Message Queuing.
Anybody else with better ideas is very welcome to help out!
Kind regards,
This demo comes with a Microsoft SQL server 2000 CD which is one of the required elements for installation.
The system indicates Microsoft Message Queuing as the missing element.
Message queing is a part of Windows, it comes on the standard installation CD. Just go to the configuration panel and select "add/remove Programs", then select "Add/Remove windows components", select "Message queing".
This should do the trick. However keep in mind that previous posts are also true, you have to install SQL server first, this is shipped with WinCC.
it is very easy u can install from windows xp it self. from add/remove windows
component.
Hi, I am trying to install WinCC on my laptop and have tried to install the message queuing service, but it now asks me for the address of a domain controller, but I do not know of any.
I am running XP Profession with SP2.
If anyone could give me any advice that would be great.
Many thanks in advance
Dear experts, Two queries: 1) Step7 professional 2010 has to be installed on a PC with Windows 7 Ultimate 32 bit. Later, step 7 v5.5 will be...
4,245
Hello Everybody I wish you can help me with installing WinCC V6.0 SP4 , i am using windows XP After i installed the instance named "wincc" of...
3,484
I am trying to install Siemens WinCC 6.0 but when I start installation i get an error report that SQL Server 2000 SP3 is missing on my computer...
11,661
Hi. I am trying to install Step 7 v5.3 on XP Pro. I have all the latest windows updates. The software just hangs up during the install. There are...
3,681
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
105
