Integer value displaying matter
Problem-Solve
May 2011
Terni
Hi All,
I am connecting siemens programm Step7-300 with WinccFlexibile Touchpanel through Ethernet so I have problem with displaying Integer value from both sides when I put integer value in touch panel and forced it doesn't get by S7 siemens while real value doesnt have problem so that I am sure my comunication is correct the matter as I think that a little bit with integer value can anybody help me to solve it I will be glad if somebody there to reply me.
My experience is fairly new so I expect to be corrected.
However - issues with the touch panels are generally caused by trying to use direct move statements
the screen handles Data Blocks far better - this enables scaling factors.
as the siemens method of bit and byte handeling differs from othe PLC's
normal integer movement fails.
The analog array has 16 individual bits and each bit is an alarm. SCADA is having issues getting the BIT bool value. However they can get the...
1,034
Hello, I need a little help. I’m looking for a way to program integer values to activate a bit for an alarm. for example... If any Integer[0] thru...
41
7,938
Have beginner knowledge of digital controls, and intermediate/advanced knowledge of socket clients and listeners (written logging proxies, socket...
3,778
Hi everyone :* I am using using unity pro v.13 i want to do the mathematical function of floor() which makes for example 1.2 to 1 and makes 2.9...
3,106
Hi, Can someone help me explain in detail this integer Value. N7[4+((N151_0 AND -16)/16)].[N151_0 AND 15] Based on my understanding in the...
2,599
