Integrated Architecture Uninstall
Spinjack
Aug 2012
Anywhere
Does anyone know the procedure for the removal of Rockwell's Integrated Architecture program and all the various components that go with it?
There is no removal tool that I could find and the Add/Remove Programs part of Control Panel doesn't list the programs.
The program is huge and used up most of my SSHD. I need to put in on an external drive. But first, it needs to come off my internal drive.
Google searches have led nowhere so far. Maybe I'm not using the correct key words. :dunno
Thanks.
Integrated architecture by itself is not a single program. It refers to numerous different programs and equipment working together. Or are you thinking of Integrated Architecture Builder? If so, it's usually denoted as IAB. Look in a folder called something like Rockwell Software (I'm on my phone right now and not my PC), it usually creates a folder like that on install.
Looking at someone else' PC, IAB is under the folder called Rockwell Automation with its own tab, the program is called IAB.exe. But it doesn't come up under the Windows add/remove programs tool. There are a lot of registry entries, so I would not just delete the exe file. You should get help. The Knowledge Base doesn't have anything specific in it, other than to send an email to [email protected].
Try running again the installer. Since the software is installed, probably you will find new options for modify/repair/remove it.
IAB is the single utility, yes. I was thinking about how to remove all of the associated programs as well.
As it turns out, I made a bad assumption. My memory issues arose shortly after installing IA, so I immediately went after it as the culprit. It was just the straw that the overloaded the camel. Downloaded some utilities and found 130+ GB of junk (temp files, log files, etc.). All better now. Still want to put IA on an external drive, though.
Hey guys, I'm new to Rockwell IAB. I was trying to use it to help me document the existing layout in a cusomer's plant. They have a 1756-L55...
2,865
So I'm trying to use IAB. I need to know what materials I will need for this Point I/O extension. Essentially, I just need to make sure I have...
2,350
Hello, Can anybody help me getting the installable for Rockwell Automation's Integrated Architecture Builder (Lite)? It's available at the link...
5,657
Hi All, I am currently trying to setup and architecture using AB's IAB for a SLC-5/05 rack. Our company likes to use the quick wiring solutions...
3,506
I downloaded version 6.01 but the tutorial evidently didn't come with it since the drop down is grayed out. Anybody know where I can download it...
5,163
