Integrating floppy with machine options
wnkook
Oct 2003
Akron, Ohio
18
Hello,
I have an application and I am wondering if it is possiable to integrate a floppy disk to a compactlogix PLC to load process files into the machine.
I was thinking it would be possiable to use the structured text to handle the interface.
Or do I just go with an industrial computer with a front-end. And if so what would my options be.
Currently I'm looking at the versaview with an hmi package.
Jason
I wouldn't waste too much time trying to make a floppy drive "interface". The new Compactlogix processors come with a built-in CompactFlash card slot.
Depending on what you mean by process files, it would probably be best to use an HMI front end of some sort.
More info
Hello again,
The application is a cut saw. I can feed data strings into my recipe's but they want the option to add and retrieve files by floppy...
Now I'm curious if I could use the flash card for this...
Thanks,
jason
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
675
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,563
Hello, I have a application where a analog input will be constantly updating a value in a PLC. What I want to do is mathematically integrate these...
2,435
Hello I really need help here.. So I upgraded my wonderware from 10.0 to 10.5 edition. When I try to connecting the OPC(in PC1) to Intouch (In...
1,402
I'm trying to integrate an analog module EXM-AMM 3HT as an extension for Pfxlm 4301 taddc. The documentation I've found so far is awfull. How does...
1,330
