Integrating S7-PLCSIM & Intouch
MrNobody
Feb 2009
Malaysia
22
For testing purposes, i need to integrate S7-PLCSIM with Intouch 9.0.
How can I do it? What protocol should I use? Can I install both S7-PLCSIM and Intouch in 1 virtual machine or do I need to install them in 2 separate virtual Machine?
Pls advice. Thanks.
If Intouch can use the socalled S7ONLINE connection type, then it should be possible with the latest version of PLCSIM.
If Intouch uses a native driver, then it is not possible.
If Intouch uses OPC, then maybe it is possible.
In the latest service-pack for PLCSIM, it is mentioned that it is now possible to integrate it with a Simatic PC Station.
I am not sure exactly what that means, if it is for example possible to make a connection via OPC to PLCSIM.
This has been a user request for PLCSIM for a long time.
Hi!
You have to start an additional programm:
http://sourceforge.net/projects/nettoplcsim/
You can run InTouch on a VM and connect it to PLCSim on your host, or you can run both on your host - I've tested both versions.
The connection you have to use is ISO on TCP (I use the DA-Server that is delivered with InTouch).
You have to set the IP of your network card to the IP your PLC will later have (or set the IP in the client configuration to the IP of your network card).
Make sure your host accepts incoming connections on port 102.
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
683
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,578
Hello, I have a application where a analog input will be constantly updating a value in a PLC. What I want to do is mathematically integrate these...
2,449
Hello I really need help here.. So I upgraded my wonderware from 10.0 to 10.5 edition. When I try to connecting the OPC(in PC1) to Intouch (In...
1,409
I'm trying to integrate an analog module EXM-AMM 3HT as an extension for Pfxlm 4301 taddc. The documentation I've found so far is awfull. How does...
1,335
