Thomas Sullens
Good question.
Mostly because it was specified.. it matches their other equip.etc.
Secondly, at 500hp I'm guessing W-D is significantly cheaper.
W-D is probably not going to be cheaper and something else to consider is wire size. Is it specified too? The reason I`m bring this up is two years ago we changed out a auto transformer starter to a solid state it was on a 500 hp 480 volt motor the starter wasn`t the problem. The problem was it had 3 - 500 mcm`s per phase and there is no way I would put a plc in this enclosure if it would fit. Ask the Engineer if he wants to be the one to trouble shoot it ? Use NEMA if you want it to last.
Good Luck banghead
Good Luck banghead
