Intellution iFix
learner
Apr 2007
British Columbia
81
Hi there,
Does anybody know if Intellution is compatible with AB PLC compact logix and control logix?
Also is there any common hand held device ,except laptops, that can talk to AB compact logix.
iFix works with Compactlogix BUT the standard ABR I/O driver does not (at least it would not a year ago when I tried to implement it). I had to buy the IGS or IGX driver (memory fails me) from Intellution for about $400.00 to make it work. AB tech support helped out after the Compact just would not work on the same type comm setup as the SLC 5/05's. I think that the Controllogix is capable of using either IGS or the ABR driver though.Steve
It's been a while since I have used the IGS driver, but I believe that you also save money because you don't need RSLinx with the IGS. I haven't seen any issues with using the IGS driver on SLC or Control and CompactLogix.
We are using the opc driver with linx to talk to an slc and a plc5 through a dh+ card in a control logix chasis. We were using the ABR but it started acting up and we could never get it to reestablish comms. So to sum up it works either way. Just a lot less configuring if you use the opc. All 20 or so of of l32E compactlogix use the opc as well.
Yes, there can be a big savings when you have a plant with many plcs.
I install IGS but iFix SCU doesn't see it. The notes say to install in the default PDB folder, which I did.
hello guys following errors ocurrs during trying to starting mission program 1. workspace.exe has generated errors and will be closed by windows...
1,538
I am currently working on rebuilding a computer that had Intellution iFix 3.5 on it. The original installation disks have gone missing and unable...
2,526
Hello, I am receiving a runtime error in my Intellution IFIX 3.0 as follows: Runtime Error '-2147200630(8004518a)': Automation Error can...
3,366
Hello, I am using the iFix Scada version 2.5 and i am facing a problem. Once i open the PC and try to open iFix i get a message that the driver...
2,746
I am new to the world of ifix and cannot figure out how to save and have multiple projects to select from. I have a customer running Ifix runtime...
39,531
