Interface Sixnet VT Modem with 1761-net-eni
pembry
Jul 2009
VA
19
I have two location. Location 1 has a VT-Modem-1 connected to a MLGX 1200. Confirmed to be working by connecting from offsite locatoin.
Second location has a VT-Modem-2 which connects serially to a 1761-NET-ENI.
The second location has a current Ethernet I/P network. The equipment we want to interface information from the 1200 to is located in a differnet building from the main processor.
The goal is to be able to message from the 1200 to an Ethernet I/P device through the modem connection.
I can not get the ENI to connect. I have confirmed that my modem at location 2 is connecting as I can connect my PC serially through the modem and go online with the processor.
I have tried:
PCM02 cable direct
PCM02 cable w/ Null Modem
Straight through cable
Straigh cable w/ null modem.
Buad rate and serial settings confirmed in both the ENI and the modem to be 19200,8,n,1
Cable is Din pin 4 to DB9 pin 3, din pin 7 to DB9 pin 4, din pin 8 to DB9 pin 5
Have switched 3/4 on this connection as well.
Any ideas. I think this is possible if I can just get the right cable. Has anyone done this or something similliar?
Thanks,
Pat
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
50
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
204
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
902
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
238
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
130
