interfacing plc to a 8051 based system
is_razi
Aug 2003
tabriz
hi,
i want to interface a 8051 based system to siemens s7-312 plc through a mpi cable ,so i can send some data to plc or receive from that.
please guide me to do that.
thanks very much.
Search this forum and you'll see that this question has come up on numeruous occasions. The answer is still the same: NO, YOU CAN'T DO IT!
Why? Because this is a protocol owned and very well guarded by Siemens. Only if you're prepared to pay about a common yearly Western-European programmers wage they are prepared to discuss the possibilities of selling their secrets.
Good luck!
Or, dare I say, switch to Allen-Bradley. I designed a hand-held using an 8051 to interface with the SLC 500 and Micrologix 1200 using their DF1 protocol manual available on their web site.
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,059
hello, Can anyone help me regarding the logic of interfacing ELITE 440 energy meter with M200 PLC over Ethernet. Elite 440 is having Ethernet...
3,855
Can somebody help me with interfacing of Schnieder EM6400NG multi function meter with m340 plc using modbus. i want to read KW (Power) of load.
1,650
Hello All, Is there anyway of directly interfacing the Maxim 1 wire protocol to a PLC? Thanks Carl
2,255
Hello, I intend to connect to a ControlLogix 5571 PLC through a work station and program it. One way is to install the RSLinx driver and then use...
3,622
