interger ASCII to String Conversion SLC5/05
Yurikei
Oct 2008
Swindon
Hello all
i am a long time reader of this forum but first time questioning
i am having a problem with converting acsii code, i have ascii code being wrote into a Interger Data file on my SLC5/05 but using the Integer to string conversion AIC this only convertes it as a number but i need to read it as ascii code/radix.
have i missed something or will i have to setup part of the program to convert manually
Cheers
Try using the COPy instruction to copy the integers into string files. COP is a bit for bit copy, and the destination file type determines the length. Since there are two ascii characters per integer, you will want to ensure that your destination ST file is twice as long as the integer file you're copying, and set the length of the COP accordingly.
Hope this helps.
Paul
Hi Guys I wrote a programme which compares values in a counter to a pre set value depending on a number of calculations. I am using a Keyence...
1,675
Panelview 1000e, rio tag for long interger. Need to have a f file in the plc 5 read the same on the panelview screen. Did a copy f8;1 to n7:100...
2,231
Hello All, I would like to change interger value to Strings 1. Time format and 2. Date Format. Now i got these value in Interger but i don't...
2,541
I am using a ab 1500 micro logix and i need to convert flaot to interger. The card manufacture said all i need to do is do the following...
1,523
Does anyone have an example of converting two 16bit integers N10:0, N10:1 into a floating point F8:0? This is very new to me and Im tyring to get...
44
11,186
