Interlink two RTU
NR16
Sep 2013
Port Louis
Hi Everybody
I need to interlink two RTU which is (i) 200 meters and (ii) 400 meters between two lifting station.
What methodology is best suited and cost effective to interlink the two RTU. The RTU's communicate with each other and the master station we can also control, monitor and viewing alarms.
Also is Modbus/TCP appropriate?
Thanking you in advance.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
52
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
234
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
273
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
119
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
522
