interlocking in plc program
interlocking can be considered in several ways.
stop and go signals between machines is a good example.
consider a large press that makes car doors and has 3 machines.
#1 robot to load the part.
#2 the press itself
#3 the robot to unload the part.
you press the start button (machine is empty).
the system looks to see of everything is in the home position.
yes, keep going - no give an error
1. robot 1 loads the part and goes home.
a part loaded signal is sent to the press.
2. the press operates and goes home.
a part processed signal is sent to robot #2
3. robot #2 removes the part and goes home.
a part removed signal is sent to robot #1 to load the next part (step 1)
this is a very simplified version of interlocks, but you can see that each machine depends on the signals from the others.
I hope this helps,
james
Does any body know why plc interlocking is not reliable? Why is needed to use external interlocking like contacts interlocking when using plc...
6,582
Can you interlock your plc with n/c contact of your motor overload relay?
5,451
I have a function where I have set it to qty interlock, how should i interlock it in the motor block ... :huh:
1,102
I just have a little task I’m trying to complete, and I wonder if anyone has any suggestions. I have a crushing operation running with 3 separate...
2,070
I have 2 Logix based systems that I need to Interlock together and read and write data in both directions. In the compact Logix system I have the...
2,263
