Internal bits in Rslohix 5000
weilerot
Nov 2004
19
I have searhed the threads for an answer with no luck. In RSlogix 5000 there are no B:3 bits for internal relays. Can I just assign a tag to a output coil and have it function as an internal relay? Hopefully I did not misspell anything, I had cataract surgery this morning. Hard to see clearly.
Thanka in advance,
Herb
Go rest your eyes in a dim room. That's an order. Get back to this stuff later.
In RSLogix 5000 all you need to do for an "internal coil" is create a Tag with a data type of BOOL. If you want to have a bunch of them grouped together for convenience or functionality, you can create a BOOL[x] array (I always use 32 bits but they can be bigger).
Or you could make an Array of INTs or DINTs and address them at the Bit level and use them as bits. Then the addressing would be similar to RSLogix500.
You could make an array called B3, INT[20] and you could address them B3[0-19].0-15
But the good thing about tag names is you can set them to mean something. Machine_Bits[0-19].0-15, etc.
Hello there, I'm trying to send the state of a single internal bit (B3:3/8) of my main ML1400 PLC to a different ML1400 over Ethernet using the...
1,767
Hi. I hope you guys can help me to resolve the issue as stated below. I have already emailed the GE Tech Support regarding this but after a week...
6,200
Hi, just wondering if anyone could help me out with an internal reference . . . ?? I'm using a Micrologix 1500 LRP, and it has a BAT. LO LED...
2,664
I'm writting a program for a packing machine. Say from the start to the end the quantity of packs are 20, with a couple of sensors placed at say...
3,570
Hi, I understand that all physical inputs are scanned during the "input scan" before the "program scan" phase. But is this true for internal...
7,200
