SoftwareJanitor
We seem to have bad button response across applications here when trying to write a single bit to a (Rockwell) PLC (to reset an alarm, for example). It can take several clicks of the button, even in a rapid-fire fashion, to get it to work. And it's not a case of the PLC writing over this same tag at the same time. It's typically a rung contact being read by the PLC, and Wonderware just needs to write the bit to the tag! The buttons are typically defined as discrete/direct.
I've also tried a small script which writes the value, loops 10,000 times, then clears the value, but the performance appears to be unchanged.
Anybody else experience this with Wonderware?
