Intouch 2017 WindowViewer Failed to open
kratos1
May 2017
viet nam
25
Hello everyone.
Please help me to solve this issue with Intouch 2017. I get notice “ Failed to open Intouch Application” when I try to open my project. It was working before suddenly happen this issue. I check logger in SMC but also can not open logger. Got notice : Unable to connect to Logger . If running on Windows Server 2003 SP1 or Window XP SP2, verify that you have run the OSConfigurarion Utility to ensure correct services login….”
Thanks for your reply. Yes, Archest logger is running and set in automatic. And I have tried to run Osconfiguration Utility, disable DEP, PAE but still can not open Logger.
Sounds like the services have an administrator level credentials problem. When you installed the software, you should have registered the services to an administrator account for which the password will never expire.
Hi everyone, I have activated Intouch 2017 in Schneider Electric License Manager. After that I reinstalled window and Intouch. I tried to...
6,567
Greetings, I am a junior engineer, I am about to take the CSI exam to get certified in InTouch 2017 to apply for a job. Can anyone who has taken...
1,041
Hello to all of you! I am working with InTouch 2017 application for HMI. So far, so good - configuration is simple, there is two clients, each...
1,440
Hi! We are currently updating our Intouch 2012 (v10.5 and v10.6) and Intouch 2014 (v11.1) to Intouch 2017 (v17.3). We were using workstations as...
4,363
I have generally not been required to implement security in InTouch applications, so if there has ever been a need, then have used the InTouch...
2,897
