intouch compact edition problem
PainAmplifier
Jan 2012
Monterrey
I'am running in touch compact edition on kontron Panel PC with windows CE, and communicating with SIMATIC S400 PLC through TCP/IP protocol. The problem is that application reciving statuses very very slow. I try to ping PLC from panel PLC 1 ms TTL, I try to run application on normal PC with DASSDIRECT driver working normaly. Intouch compact edition is using sieth driver for siemens S400 PLC. Somebody had similar problems??
Hi all, I have a problem with wonderware 9.5 comms over VPN.. We have a set-up where we connect Scada and two PLC'S through VPN connection...
3,464
4,511
Dears , i have new compact logix PLC with firmware V19 and wonderware in touch version 9.5.I am trying to communicate through ABCIP IO server but...
3,589
Hello, I have an HMI running an Intouch 9.5 application. It is communicating with a compact logix PLC via an external I/O server. The Intouch...
2,873
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
