InView Panel Displays In-accurate temp.
gado
Aug 2007
Legaspi City, Albay
Guys,
Kindly help me sort this thing out. We are monitoring our winding temperature thru 6-points with one RTD each. 5 points are reading an average of 78 deg C while one point reads only about 57 deg C.
I did verify the reading by hooking my laptop and get on-line reading.Surprisingly, all 6-points are reading almost the same but on the inview, that one point previously mentioned has a difference of at least 15 deg C.
Where you guys think the problem is?
Cheers!
gado
You did not mention the plc but I have to "assume" that something has altered how the program is doing the scaling OR the HMI is altering the numbers after reading them.
Hello let me explain my problem. I just got tossed into a somewhat complicated job because the person that normally does the writing is on...
3,830
Hello; I'm programming a 1200 with RSLogix and a InView Panel 2706-P42R with Inview Messaging Software. I'm struggling with how to make the plc...
4,172
Hello Friends We have a Inview 2706-P72CN2, it had been working OK. Showing OK Parts, NOK Parts and Goal Parts. Suddenly, it has stopped working...
332
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
909
Currently I'm programming a Controls Spectrum InView P42C-SC using a ControlLogix. The display has an ethernet communications module attached to...
1,340
