IO power with ethernet
TConnolly
Apr 2005
Salt Lake City
6,152
I'm desigining a system right now that uses ethernet IO and I need about 2 amps of 24VDC at the IO cabinet, which is 45' (14m) away, but the route is somewhat convoluted - a conduit benders nightmare. I'm planning on only a single 3/4" couduit.
Is there an adaptor which will allow me to supply the dc on the unused conductors of the Cat-5 cable?
Or is that a really really bad idea?
Alaric said:
....Or is that a really really bad idea?
I'd think so. Considering the wire size of the cable I wouldnt feel comfortable with it. Also if it's a switching power supplies you may get some noise on the E-net.
Note: I've done this in our own building (about 200') and seemed to have gotten away with it, however I would never do it to a customer.
Google 'Power Over Ethernet'. It shows schemes that allows low wattage transmission of power for specific ethernet devices (hubs etc) at the other end. It probably wouldn't be prudent for your application though.
Before I did that, I'd pull a three conductor 18 gauge shielded cable with the cat5 cable in the same conduit. Probably not the right thing to do either though ... but it would most likely work fine.
I find this weblink really interesting. I will consider playing it around over the coming holidays!:D
If it is good I will incorporate it into the company's ever-failing network.
A little extra calculations, I should think it's not a bad idea.
Well, that what I had planned on doing, but as I started thinking about wat a pain it was going to be to get the wires into this already convoluted conduit routing, I wondered if there was such a thing as power over ethernet.
PoE is an IEEE standard now. Green and Orange are your data wires. PoE spec says that Blue + Blue/White is +vDC and Brown + Brown/White are -vDC.
http://www.altair.org/labnotes_POE.html
IEEE spec is 48v and 12.95W max. I've run 24vdc in one side and powered a 10" EZ-Touch screen (~1A) on the other a few times without problems at about 30-40 feet.
I'd go with a shielded CAT5 cable and a shielded 18ga cable for your power. Much more reliable in the long run.
Hi all, Im having a weird problem with my panel and i think its the plc causing it but it could be some other component. When i power up my...
2,555
Has anyone seen any POE EIP I/O blocks? I have to ASSuME a company makes an input block. The unit wouldnt be able to do much with any output maybe...
1,600
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,080
I have quick question and any help would be appreciated. We had to replace a power flex 525. So we pulled the parameters from the old one and...
24
6,189
Hi; I have 02nos AB Stratix 2000 (1783-US05T) Ethernet switches having 5 ports. I have a problem that the Power indications of both switches...
1,942
