IP Reset Beckhoff CX1010-N000
jkamstra
Aug 2015
Hamilton
I am just learning to work with Beckhoff controllers and am trying to set up TCP/IP communication with a Siemens S7-300 PLC. In the process I accidentally messed something up or have forgotten the IP address of the controller itself as I am not longer able to PING it at the expected address. o_O
I am also not able to find it in the System Manager > Choose Target > Search (Ethernet) > Broadcast Search method.
Is there a way to retrieve the IP address of the controller or to factory reset the controller?
I saw a thread here talking about factory resetting a CX9020 but my CX9010 has a compact flash card which I do not have have a port for on my computer.
Any help is appreciated, thanks!
Jon
Whoops! Thanks for the reply Archie.
I wasn't paying close enough attention. I have a CX1010 which needs to be reset (not CX9010).
In the mean time I picked up a CF reader and spoke to NA Beckhoff Support and their suggestion was to run Wireshark to find the IP address (which showed me the address - which was set to what I thought it was) but I am not able to PING the Beckhoff. Wireshark had multiple messages in the log which were:
385 28.000032000 Beckhoff_1e:25:3a Broadcast ARP 60 Gratuitous ARP for 172.16.25.13 (Request)
AND
386 28.110905000 172.16.25.13 172.16.25.255 NBNS 110 Registration NB TEB-830<20>
The only devices on the submask right now are my PC (172.16.25.100) and the Beckhoff (172.16.25.13) so I don't think there is a IP conflict.
So I think I am just going to overwrite the Beckhoff CF and restart, I'm just in the testing stages now so it isn't a big deal.
Jon
I can't for the life of me figure out how to perform a factory reset on a Beckhoff CX9020. There is nothing in the documentation. Help? Bigger...
13,736
HI FRIENDS I am using beckhoff industrial PC in that i am using Devicenet Module.I want to reset the module during running. Is there any command...
4,677
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
33
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
335
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
87
