Is Simatic 505 still a valid platform to start with for SCADA?
tgreif
Jun 2002
30
I have a client that wants to upgrade their plant SCADA system. They currently have a system comprised largely of old TI-500 I/O with TI-565 processors. They're aware of the difficulty obtaining support (parts) for the old stuff. CTi still makes campatible modules and they've requested that the new system be based on the Siemens Simatic 505 line using either Simatic 545 precessors or CTi series 2500 processors. I don't want to tell them they're nuts to go with that type of equipment but I'm having a problem justifying staying with that platform for a complete redo of the SCADA system. They're using (and will continue to use) a Wonderware HMI package. This is not a large system, having probably only about 1,000 hardwired I/O.
I don't generally see much Siemens gear in the Water and Wastewater field so I'm not sure if my concerns are valid. Will this product platform be supported for the forseeable future?
Some of the 505 line has entered mature status.
There is a listing at this link: http://www.sea.siemens.com/automat/product/plc/505/au505dl.html
But if I was the customer, I would also go with the 505 series, it is one of the best for process control. It is getting difficult to find parts for the older 500 series I/O and a refurbished 565 cost as much as a much newer model. But even though there are a lot of 505 cards on the mature list, there's a lot of used/repaired units out there.
BTW,
what are they going to do with the old stuff? I might would be interested the old stuff, still have a few systems of similar vinatage.
Ken
Not sure what they plant to do with the old stuff Ken, but I'll let them know that you may be interested in it.
Thanks for the reply.
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,271
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,671
I'd like to start by saying that my background in engineering is mostly mechanical, and I have a tiny bit of experience with AB and RSLogix (to...
2,659
Hi, I am currently looking at having to convert a SIEMENS SIAMTIC TI505 plc into an AB PLC. Let me start this off by saying I don't know much...
17
16,437
Hi: I have a CTI-2552-A card which is "isolated rtd input". The card replaced a 505-7038. The temperature values are reading too high, on all...
1,311
