Issue communicating with Wonderware OI Server
Dirk Diggler
May 2020
United States
Hello All,
I'm having a weird issue with wonderware and don't know what I'm doing wrong.
I upgraded my processors to L81 and wonderware to 2014R2 from 9. I also installed OI server. I'm seeing no communication anymore. The application name has been changed to ABCIP.
If I run the new processors with the old wonderware app and DA server it works but not with OI and the new wonderware app.
Is there something i'm not doing right?
The OI server is configured the same as the DA Server. No changes in the wonderware app apart from the application name which is changed from DASABCIP to ABCIP. The previous processor is a L71. The L81 Is running on version 32 and so I upgraded the driver to OI.
You may be able to find something in Logs..
System Platform Management Console>Log Viewer>Default Group>Local
Also it will show if License is an issue.
Thanks for the suggestions guys. Yes I have a valid OI license. Logs show "Tag database retrieved and tag upload started", "First 32 tag additions are license free" and "Server is licensed"
I'm a little new to the Automation Industry and I have encountered the following problem that advice would be greatly appreciated on: (I have...
4,450
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
145
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
206
