Issue with MRJ4 drives
rejoe.koshy
Dec 2011
kolkata
195
Hi Folks,
I am in the process of retrofitting MRJ2 (Mitsubishi) series with MRJ4 servo drives for two axes. I did use the conversion kit provided by Mitsubishi but as soon as I power I am getting an error " 20.1" on both drives which as per the operating manual is encoder error. I tried everything from checking the encoder wiring, changing the parameter "PC04" (switching from two wire to 4 wire encoder etc) but just cant seem to get over it.
Eventually , I checked "PG" and "N" points at the encoder terminals where it should have 5V to power up the encoder and could find it. I guess that's the issue where is not generating 5V for the encoder and that the drive is faulty . But the thing that confuses me is that how can the same thing happen for two brand new drives .
I am stuck....Please help!...is there any parameter I need to set which might activate the 5V at these terminals ??
There is document "Transition from MELSERVO-J2-Super/J2M Series to J4 Series Handbook" (L(NA)03093-D) from Mitsubishi and everything is very well documented and explained. It has 654 pages. There is good flowchart of procedures for replacement. Try it.
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
58
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
47
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
164
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
208
