Issue with vibratory bed
wesselvos
May 2016
Kaatsheuvel
21
Hi!
Currently running into an issue with a new vibratory bed we're installing. Its using 2 motors which are connected to 1 powerflex 525. Problem is I keep getting overvoltage faults (F005). The drive is connected to a brake resistor. I have done the following, please let me know if anything looks off.
1. Added the 2 motors powers together and set them as the power in the powerflex.
2. Added the 2 amps together and set them as the amps in the powerflex.
3. Set param 437 to the setting for a brake resistor.
4. Left param 438 to the default setting of 100%.
5. Increased accel and decel times to 10 seconds.
Is the brake resistor working at all ?
It will get physically hot. Be careful not to get burned !
Another issue is that possibly the standard brake resistor is too small for the job.
Disclaimer: I have limited experience with PF525.
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
61
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
48
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
164
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
208
