It Turkey Day and my mind is blank
asterof
May 2007
Califonia
554
problem
I have a solution of 25% sodium and 75% H20
During transfer I want to reduce the 25% to a ratio of
10% sodium and 90% water
If the total transfer amount is 80 gallons the
the original targets would be 20 gallons of sodium and
60 gallons of water based on the 25% solution.
So here is were I am lost
I would need to increase the water amount by ?? to maintain the
80 gallons at 10%.
For some reason I just am not getting it
You would use 32 gallons of the original 25% solution and add 48 gallons of water to get your total batch of 80 gallons at 10%.
Hi
So you have a mixture of 25% Sodium and 75% water in a tank/vessel and you want to pump some of that mix plus more water into a new tank/vessel to end up with 80 Gallons at 10% Sodium and 90% water?
Is that the question?
aI think it looks like this at first glance
32 gallons of mix plus top the rest with water to 80 gallons
Based on 0.25 of a gallon sodium in mix 1. so 4 gallons gives 1 gallon of sodium
10% of total is sodium so 8 gallons so 8x4 is 32 gallons required plus the top up of water
Yea but
Again
But we want to reduce this to 10%
So if we stay with 80 gallons total at 10% then the ratio
needs to be 25/10 or 2.5
So the 20 gallons of Sodium becomes 8 gallons of sodium
and 80 gallons of water metered at a 10% ratio
I think
so at 1 gallon of sodium we would have 10 gallons of water
1 > 10
2 > 20
3 > 30
4 > 40
5 > 50
6 > 60
7 > 70
8 > 80
I will toss some code and post it see if it works
After re-thinking my first answer and reading some of the other posts, I believe I misunderstood the end point target. 29.09 gallons of the 25% solution would contain 7.2725 gallons of sodium and 21.8175 gallons of water. If you add 50.91 gallons of water you would now have a solution with 72.7275 gallons of water and 7.2725 gallons of sodium. That brings the total amount of solution to 80 gallons at 10% strength.
Just to throw a monkey wrench into the works, are you actually concerned with concentration by volume or concentration by weight? Different answers are required for each.
I hope it's really a salt, sodium chloride, not elemental sodium, a metal.
Elemental sodium reacts violently with the hydronium ions in tap water releasing enough heat to self ignite the hydrogen created.
The graphic shows the typical chemistry class experiment when someone drops a bit of sodium into a beaker of water:
Hi all, For the folks in Turkey, I need a EA-MG-PGM-CBL(PC to PLC USB cable) for a Click PLC. We have a field guy in the city of Bursa who needs...
2,747
I have the refresh Alarms button, and there is no other button I need on my alarms list display. I click refresh and it all goes away on my...
1,887
Good Afternoon , I like to keep all the spare drives the same in the plant. I'm doing a project , but I ordered my drives months ago , and...
2,141
I persist with my efforts to "reverse engineer" the logic program for a vacuum process tool. This is a GE 90/30 application. In study of the...
3,057
I have a strange fault on a capacitive sensor which follows. On a packaging machine, a capacitive sensor detects a moving belt that has metal...
2,783
