iVu Plus Banner/ PV+
I would be amazed if you could.
Does the iVu Plus provide an ActiveX control for use on Windows CE 4.1 ? That's about the only way you're going to get a non-static image into a PanelView Plus 600.
The PV+6 (700-1500) does offer the embedded Internet Explorer (on the "with CE features" option) which often gives you a method for accessing things like this.
The iVu comes with software that pulls each inspection onto a PC when the camera is triggered. So the iVu is constantlly sending out each inspection, just wouldn't know how to capture it with out setting up a permanent pc out on the line just to display each inspetion. I know the Redlion HIM's come with driver installed to capture.....but maybe not with the PV+
Red Lion has a Banner driver for its G3 series that will do this, one more reason to look at them.
Good Evening , I installed a Banner IVU Plus BCR to check the barcode on cartons. This conveyor is running about 140 cartons a minute. I am...
2,201
Good Morning , I have a Banner IVU Plus BCR , that I need to replace a 4mm lens with a 8mm lens . How difficult is that ? Are you folks...
1,694
Good Morning , I am getting ready to install a Banner IVU Plus BCR in a ControlLogix . It seems like it is easier to install the IVU Plus...
1,413
Good Evening , I purchased a Banner IVU Plus BCR , and took notice there is a CD in the box. Not too familer with Barcode Scanners. My...
1,981
Good Morning , I am trying to set up a Banner IVU Plus BCR for the first time . I never worked with a barcode reader before , but it seems...
1,482
