Jan Steen Nielsen FB121 won't work...
nightline;499357
Gents,
I've a machine with a S7 313C PLC, and have to control a temperature. At this moment it's done by some timers, with a lot of temperature alarms.
So I found a sample program from Jan Steen Nielsen from Danmark, who programmed a FB121 Pid controller.
I've copy passed the FB121 with the DB121 instance block in the controller.
I've put the FB121 in FC70, and created the Data in DB70.
If I monitor DB121, I see a lot of parameters changing, except the output variable.
Has anyone any idea, what I do wrong?
Or is more information needed?
Thanks in advance!
Jack
Reply:
I'm Jan Steen Nielsen and know what you doing "wrong".
In fact, it is Siemens that doing something wrong - not you!.
Instead of giving you a longer explanation, then please send me a mail and I will give you (and others that might read this) the latest version of my work, where all that kind of
problems are removed by a smart trick in the programming.
Regards
Jan Steen Nielsen
Denmark
[email protected]
FB121 PID-Controller.
Reply to Jack:
Regards
Jan Steen Nielsen
Denmark
[email protected]
Sorry to here about the phantom of 'Jack' - do you want your money back (USD = 0) or do you want the new Siemens-errorfree version of FB121? -(among many others usefull functions). Think again my friend.
@PLC
Your joke wasn't very funny. Jan Steen is only trying to help.
The OP had an issue with format errors on his real values. Then no algorithm will run properly.
@Jan Steen
I am curious why you would put effort in making your own controller FB. Did you face problems with the Siemens standard blocks?
Regards
Kalle
Yes, it was funny
For Jan to blame it on Siemens is pretty arrogant
fb41 has been around for what 20+ years
Why re invent the wheel
I just noticed this.... http://arstechnica.com/security/2014/06/attackers-poison-legitimate-apps-to-infect-sensitive-industrial-control-systems/ rix
1,761
I don't get a lot of geek chatter - but I found this "FBI shutting down my computer" news report to be somewhat interesting ... a quick forum...
1,448
The following Step 7 project has been run using PLCSIM and contains code that flashes Q0.0 The Project is based on a UK board game called Cluedo...
4,589
http://www.theregister.co.uk/2010/07/20/win_shortcut_vuln_exploit_code/ Somebody is definitely reading our discussions about shop floor...
5,102
