Jokab Pluto safety PLC
plcguy123
Dec 2015
minnesota
Forgot the password on a Jokab Pluto PLC. Is there anyway to delete everything on the plc and download a new program or reset the password. Just to be able to use the plc (change the program) would be the end-goal.
So this is all well and good if you have a copy of the program but is there a way to upload the program without a password. My company does not have a copy of the program so we would like to create a backup but don't have the password to upload, and we can't change the password without erasing the program we don't have. Any ideas?
More that likely you are SOL without a copy of the code. Contact the folks who originally commissioned the system and failing that, contact the manufacturer. Passwords are designed to give the integrator the ability to protect their IP as well as the integrity of the system especially a safety system so it is unlikely that there is any published way to get in a "back door" to retrieve the logic which you can't prove you are authorized to access.
I don't have any experience with this particular hardware, but that has been my experience with other gear.
Good luck and welcome to the forum!
I have (2) existing machines that I am integrating together with a robot loader/unloader. Each machine has it's own RT9 safety relay which: 1...
2,830
Hi guys! I have problem when i do update OS for Pluto safety with Pluto Manager. My old version is 2.32 and i must update to 2.40 as the...
1,314
Hello guys ! What is the standard password Jokab use for the new Pluto PLC ? Tahnks
2,360
Problems with an A20 safety PLC (monitor). The machine will not reset and the Jokab unit gives error code 50 (Err 50). The leaflet that came with...
4,114
Hi all, First post in a long time. I have a ABB Pluto Safety PLC B20. I"m trying to monitor several doors via the StatusBus feature. I'm unable...
1,506
