dbh6
Hello All,
PLC is a SLC504
I have an application through which i'am to control a extruder forward and reverse (0-100%) using a joystick. Now when the operator uses the joystick the joystick will trasmit a 0-10V signal to a 1746 Ni8 analog input card module, count ranging from -32768 to 32767, which is scaled to 0-10V then based on that analog value received from that joystick we will control the Extruder using a analog output module ( type not decided yet). So basically get a 0-10V signal from joystick then use that 0-10V value to control the analog output module 0-100%.
Now their are four positions for the joystick. For example for simplicity when the joystick is free meaning when no one is using it, lets say the voltage reading 4.9 volts. That means at 4.9V the extruder should not move. Then lets say anything from 0V to 4.8 V the extruder moves backwards, and finally voltage value from 5 all the way to 10V the extruders moves forward.
How can i make it so based on that example control the analog output card 0-100% value? to handle the joysticks forward, backward and neutral positions??
PLC is a SLC504
