JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,325 Dec 7, 2010 #1 If you shall ever have to make a WinCC Flexible panel in order to connect it to an S5 PLC via the PG port (for example for replacing an old defect operator panel), then be sure to read THIS guide !
JesperMP Lifetime Supporting Member + Moderator OP Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,325 Dec 9, 2010 #2 The guide has been updated with some significant additions. The link is the same.
uptown47 Lifetime Supporting Member U Join Date Feb 2008 Location Over there, next to those boxes Posts 1,146 Dec 9, 2010 #3 Jesper, Great guide. Thanks for sharing. ;-)
JesperMP Lifetime Supporting Member + Moderator OP Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,325 Jan 20, 2011 #4 Update: The guide has been corrected for an error pertaining to how the scaling of S5 timers should be done. The link is the same.
ayman metwally Lifetime Supporting Member A Join Date Dec 2003 Location Cairo Posts 258 Jan 20, 2011 #5 Thanks.
