KEP server & Cimplicity
rejoe.koshy
Dec 2011
kolkata
195
Hey guys,
I am entrusted with the job of reviving an old data logging system which has been dysfunctional for a few years.I have discovered a couple of softwares installed on the system & would like to clearly understand the role of the software.
1.KEP SERVER
2.CIMPLICITY
Pls help me in understanding the utility of the softwares & their role in data logging.
Pls help!
1.KEP SERVER
Kepware is a piece of software that simply lets your computer read/write data to a PLC. Providing you have the correct drivers installed & tags set up. Pretty useful software that ive used many times with different drivers (Link)
2.CIMPLICITY
Ive never used cimplicity, but after searching for it on google it appears to be SCADA/HMI Software. Im guessing this is used around your site?
Ive made an assumptions here that you're SCADA/HMI software is already using Kepware as a means of communication to read/write data to the PLC.
If you wanted to log data from a plc, look for an option in the SCADA software to enable data logging. This will probably need a file name, file location, frequency to log data, tags to log etc...
Hopefully someone else who has used the software maybe some help there but that the basis in majority of the software packages i have used.
Ash
Hey guys,
1.KEP SERVER
2.CIMPLICITY
Pls help!
For technical information on Cimplicity go here: https://ge-ip.force.com/communities/CC_Knowledge?orderby=-lastPublishedDate&product=CIMPLICITY__c
For KEP Ware try this: https://www.kepware.com/support/technical-support/
Most likely Cimplicity is doing the logging and is doing an OPC Connection to Kepserver to get the data from the PLC's. Hopefully the version of KEPServer that is running there is not so old that it cannot be serviced any longer. I noticed post with a link to the Kepware Website. If you follow that you can get a support ticket started. Support will be able to help you figure out why it is not working.
Hello All, I'm trying to use a panel view to communicate to a siemens 505 processor and i have read that it has to be done using a kepware server...
2,317
I need help to write KEP SERVER tags in Softlogix5800 or ControlLogix PLC(RSLogix5000) Actually In KEP Server I am reading GE Fanuc PLC...
2,028
Hi, I need to connect the KEP server as OPC (Version 4.264) to Micrologix controller. I'm procuring rslinx professinal to talk to opc as the...
7,156
O.K. people update time!! I have been trying to get a panelview plus to communicate with a Modicon PLC. All is well so far. i figured out the...
1,946
Hello all, just a cheap old cheat note. I ran into the same problem most of us have seen, that field device talks Modbus RTU and I need more data...
4,716
