Greg Dake
I'm trying to get OPC data from a Yokogawa DX230/P chart recorder into a PanelView Plus 1000. The 230/p driver DOES come with Kepserver Enterprise, but is not one of the selectable drivers which can be downloaded into the PV+. Does anyone know if Rockwell has plans to make the rest of the drivers, which Kepserver Enterprise contains, selectable for download into the PV+?
I can run the 230/p kepware driver in the quickclient and everything looks good, kind of a bummer I cannot DL it to the PV+. My only other option at this point is to use the "User Configurable Driver"...This means getting the protocol spec from Yokogawa to do this. To make it more involved, the recorder is 21CFR11 compliant, meaning I also have to authenticate with a UN/PW. This is accomplished with the already written Kepware driver, it just isn't an available one to DL in the PV+
I've talked with Kepware, and they indicated there's no way to look at the already created 230/P driver to get the protocol specs....My contact at Yokogawa is out for a week or two.
Any ideas?
TIA,
Greg
Any ideas?
TIA,
Greg
