Keyence CV-X Logging images for re-test
mcmahobr
Dec 2018
Ireland
Looking to store a 50-100 images of parts as they pass through a machine so that I can inspect them individually offline. I can't for the life of me figure out the settings to do this. So far have only been able to log 8 at most images before they disappear from the image strip.
CV-X150fp is the camera controller anyway.
Thanks!
In the settings area of the software, you can select to save all, good, or bad images to the SD card in slot 2. SD slot 2 is the slot without the screw holding the plastic door closed. I also believe there are other settings in the software to save more bad images to the filmstrip too. I don't have a controller in front of me to give examples. Your local Keyence Rep should be able to help as well...
By chance I got an email from a Keyence rep later that night.
Issue sorted now, there's an option in output settings to record image output. Enabling this did the job.
105
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
104
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
115
Hello all I've got a cell with four Keyence IV3 cameras that are saving images to a FTP server, we are also labeling the parts with a time date...
325
I will find cable series but I don't know for fs260 model, kindly suggestions and help to me for connect cable
125
