"Kick Starting" new S7-400 CPU
John Gaunt
Nov 2004
Tasmania, Australia
362
When I get a new S7-400 CPU I am able to communicate with it
straight away using a PC adaptor and PC running Step7.
About 3 times now I have had the problem whereby I am unable to
establish communications with the new "straight out of the box"
CPU using MPI. I have tried going straight to Profibus using
a CP 5613 or CP5613 A2 card but this fails also. My Profibus
setup doesn't match the MPI port setup.
I had this problem last a couple of weeks ago in India with a CPU
we had shipped there direct. This time I spent a little time
trying to understand the problem.
Using PC Adaptor with PG/PC Interface PC Adaptor (Auto)
Properties / Start Network Detection
Network Type PROFIBUS
Trans Rate 187.5 kbps
Highest Station Address 126
Profile Standard
So obviously Siemens sometimes ship their new CPU's with the
MPI port configured as Profibus.
My "work around" for this problem is to install a Flash Memory
card I now carry around with my PC Adaptor with an old rubbish
program that has the MPI port set up correctly. Then the PC
Adaptor works and continues to work when I remove the Flash Card.
I then download my projects correct Hardware Configuration and
switch to Profibus putting my PC Adaptor away until the next
project.
Obviously the best solution to this problem is for Siemens to
"mend their ways" and ship CPU's with the MPI port set up
correctly. Siemens don't want to acknowledge the problem
exists.
I think that perhaps the software Siemens provide on their
special Laptops somehow allows communication regardless of
the CPU MPI port being configured Profibus. If so they should
make this facility available to PC users.
Has anybody else experienced this problem?
Is there a better solution?
We have two identical rotary-screw ammonia compressors. Each is close-coupled to a three-phase motor equipped with a soft-start. One of the...
2,101
Can it still be a commission if the customer of my customer is giving me money back per electrical panel he builds for them?
2,759
Just spent over 2 hours trying to isolate a problem with a machine running erratically. After searching the entire program (without descriptions...
2,212
Hi, I am attempting to turn on an output for one second, every thirty seconds, but am having some trouble. I have a XIC with S:1/15 (first pass)...
610
Rather new to structured text. I'm trying to edit a machine so that it will reinitialize with some push buttons held in for 10 seconds. Pushing...
2,777
