Kinco HMI connection with Mitsubishi FX1S PLC
MohsinJahan
Aug 2018
USA
I am trying to connect a Kinco HMI (T070) with the PLC of Mitsubishi (fx1s) but I want to know how can I add PLC tags to HMI Buttons (when I will touch on button on HMI, PLC switch X0 should be energized). Can anybody here help me?
If I elaborate my question, I am simply asking about how to connect HMI tags to PLC Elements?
http://tiaportal.weebly.com
X0 is a PLC digital input, if the HMI forces its state probably it will not change.
You better use an internal bit like M0 instead X0
Sir, I do not know where should I write the address "MO" in HMI. For example I am using a toggle button and i design and placed it. Now there is no place to put the value/address in Kinco HMI software (as we have in Siemens HMI software).
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
46
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,563
Can anyone help me getting this communications connection set up between KINCO GL100 and KINCO K508-40AR? I am using Port 1(RS485) on the KINCO...
3,313
Hi all. Are someone was tried to connect HMI with only serial port ( rs232/485 ) to a PLC (S7-1200 + CM 1241 RS485 ) I have a machine, where is a...
1,247
Does anybody have experience with the data logging on a Kinco HMI? I'm currently trying to log some dumb data. I have already created the DB and...
1,093
