kinco hmi siemens s7 1200
Dec 2013
giza
good morning
can anyone help me to connect kinco hmi with plc Siemens s7 1200 using tcp and can i have simple project for plc and hmi
thank you and best regards
Good morning everyone
I make connection between Kinco HMI with Siemens PLC s7 1200
First I make factory reset to my PLC then I start to connect my PLC with indusoft scada using sieth driver and use the PDF help file for driver and make good connection then use my Kinco HMI and I have connection between indusoft scada and PLC s7 1200 and Kinco HMI using TCP IP system
Any one need help can mail me at
[email protected]
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
42
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,562
Can anyone help me getting this communications connection set up between KINCO GL100 and KINCO K508-40AR? I am using Port 1(RS485) on the KINCO...
3,311
Hi all. Are someone was tried to connect HMI with only serial port ( rs232/485 ) to a PLC (S7-1200 + CM 1241 RS485 ) I have a machine, where is a...
1,246
Does anybody have experience with the data logging on a Kinco HMI? I'm currently trying to log some dumb data. I have already created the DB and...
1,089
