It could be, but a more likely cause is mechanical. How is the opening and closing of the filling valves controlled? Is it by time or a sensor? If by time, the valve may need cleaning. If by sensor, the sensor may need adjusting.Could it be control board fault?
Yes friend,@tachmyrat
Without good technical explanation of problem and supporting info there is small chance that we can help you.
BTW, overfilling is not so uncommon method of bottle filling, where excess of material is recirculated.
Yes.Could it still be mechanical if 10-15 of the filling valves are overfilling at the same time?
And now here's a reply to OP, not the lame spammer.
