ladder scan question
cking2729
Jul 2014
texas
I have a 10ms periodic task (in ladder logic) set up in my Logix controller (v28.)
One of my routines is to MOV the decimal number "2" into a DINT tag when a motor isn't being told to run. When a start button is pressed and the motors aren't running, I need to MOV a "0" and then an "11" into the same DINT tag.
I have the logic set up to achieve the MOV's, but unfortunately the "2" is always being written and seems to always take precedence unless I AFI out the MOV "2" rungs entirely.
I am wondering what I can do or what features Studio 5000 might have to help me accomplish getting the 0 and 11 to take precedence when true. My routine to MOV the 0 and 11 comes first in the program schedule.
Thanks for the help!
It sounds like you may have logic that states if motor is not running MOV a 2.
Try adding in about the start button not being pushed as well.
This should disable the rung and allow your other numbers.
As Opera pointed out, a screenshot would be helpful.
Can you post a screenshot of your logic? Is all of this logic occurring in the same Task/Program/Routine?
OG
I will try to get a screenshot ASAP. But the MOV 2 logic is in the same task, but a different program & routine than the MOV 0 and MOV 11. Does it need to be in the same program or routine?
I think the problem is because there are only 2 states (not running and running) and the OP needs to do something when the system goes from the first state to the second one.
I'd add a third state: stopped, starting and running. This way it's possible to write the correct value in any case.
I'm not sure what you are trying to do, but just off the cuff, I would suggest that you use a one-shot (OSR) instruction just before each of your MOV's. That way, you don't have logic constantly writing to your status variable, but only writing when a condition changes.
Hello all, Does anyone know how the PMC ladder logic on Fanuc 15M CNC's solve? Is it: 1. top to bottom, left to right or... 2. left to right...
3,423
Thanks ahead for any insight or assistance... I am a machine designer of 25+ Years in a relatively new "one man band" position, I've never had...
130
156,518
Hey guys, I'm testing radio comms between my ControlLogix and CompactLogix PLCs (Xetawave 4x4e radios via Ethernet/IP). I'm using MSG...
2,260
Hi How to scan ladder diagram for trouble shoot in case of brakdown in machine. I mean is there any specific method or hit and trial method is...
4,590
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
161
