laptop connection
maddog1
Jan 2004
midwest
Hi, I a beginner and am wondering about connecting my laptop to either AB micrologix or Modicon 984 what protocal must I follow and if possible supply in detail answer as to how I access the program and actually program and or change program using modsoft/software.
Any and all help appreciated
Thanks MD1
Micrologix
ML1000: Depending on model - DF1 or DH485 (slave).
ML1200 and ML1500: DF1, DH485, Modbus RTU (slave), ASCII.
Modicon
Dont know much about this one, but various Modbus dialects seems obvious.
If you need only to connect to one PLC at a time, then DF1 seems to be the obvious choice for the Micrologix. For programming the Micrologix you need RSLogix500 and must use DF1 or DH485.
If you need to make some kind of networking between the PLCs and/or connect to more than one at a time from your laptop, then I would check if it is possible to connect everything on a Modbus network.
But I dont think that you can program the Micrologix over Modbus - only exchange data.
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,501
I'm about to have a guy onsite (I'm trying to help troubleshoot remotely) and he doesn't have the proper software. Usually I have the guys install...
1,755
Hi everyone, I have a powerflex 525 that I need to get the parameters from and onto my laptop. I used to be able to plug in the USB cable from the...
7,472
Dear all, I was using old laptop with windows 98 to communicate locally with Schneider LT6 relay. The laptop is damaged and I'm trying to...
1,663
i currently have a ge fanuc versamax micro controller and versapro as its software. i tried connecting its cable to my laptop through usb to rs232...
5,159
