Lekuru Member OP L Join Date Jun 2009 Location Boston Posts 21 Jun 17, 2009 #16 Disregards the last message.....how about this
Christoff84 Lifetime Supporting Member + Moderator C Join Date Jun 2006 Location Cambridge, ON Posts 407 Jun 17, 2009 #17 Just don't use a latch on B3:3/11. Use a regular coil output (OTE) and it will work without the timer or unlatch.
Lekuru Member OP L Join Date Jun 2009 Location Boston Posts 21 Jun 17, 2009 #18 does that mean i have to reset the output B3:3/11....and will the changes affect my initial setting at 3000
Christoff84 Lifetime Supporting Member + Moderator C Join Date Jun 2006 Location Cambridge, ON Posts 407 Jun 17, 2009 #19 No, you would not need to reset the output. Your initial setting will remain the same.
Lekuru Member OP L Join Date Jun 2009 Location Boston Posts 21 Jun 17, 2009 #20 That means this will work just fine
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Jun 17, 2009 #21 Yes, but why not replace B3:3/13 with the SUB and Timer on the same rung as your EQU and one-shot instruction? No need for the extra rung. What is the purpose of the timer?
